Ruckus H320
Product Detail
The H320 is an entry-level Wave2 802.11ac (MU-MIMO-capable) Wi-Fi access point with integrated switch in a wall-plate form factor.
H320 features Ruckus' patented BeamFlex + adaptive antenna technology to deliver high-speed 802.11ac WiFi in a low-profile design that can be discretely installed over a standard electrical junction box. H320 allows a range of wired & wireless services to be delivered in hotel guest rooms, student residences, and multi-dwelling unit swith just a single cable pull per room and eliminates the need for additional switches and power supplies.
H320 has dual-band concurrent 2x2:2 on 5GHz and 1x1:1 on 2.4GHz with MU-MIMO support.
With a 1Gbps Eth0 link to switched network, there are 2 Ethernet ports for in-room access, to connect a range of wired network devices such as IPtv set top boxes, IP telephones, or networked minibars while simultaneously providing dual band 802.11ac wireless LAN coverage. The H320 itself may be powered via standard PoE (802.3af), and can be deployed as a standalone device or centrally managed by SmartZone, ZoneDirector, or FlexMaster management platforms.
- Model Name:
- H320
- Product Family:
- EOL RUCKUS Products
- Recommended Software:
- Stability Release:
- Technology Release:
Please Wait...
Please Wait...
ID | Title | Version | Release Date | Edit Date |
20210129 | AP / ZD CLI Passphrase Vulnerability | 1.0 | January 29, 2021 | January 29, 2021 |
20210511 | RUCKUS AP Aggregation And Fragmentation Attacks Vulnerability (aka “FragAttacks”) | 1.1 | May 11, 2021 | October 15, 2021 |
20230208 | CVE-2023-25717: RUCKUS AP Web Vulnerability (RCE/CSRF) | 1.2 | February 08, 2023 | May 18, 2023 |
20230731 | RUCKUS Unleashed Authenticated Remote Command Execution Vulnerability | 1.1 | July 31, 2023 | August 01, 2023 |
20231128 | CVE-2023-49225: RUCKUS AP Stored Cross-Site Scripting Vulnerability | 1.0 | November 29, 2023 | November 29, 2023 |
20240925 | RUCKUS AP Remote Code Execution Vulnerability | 1.2 | October 04, 2024 | October 11, 2024 |
20250122 | Security Advisory 20250122: Multiple vulnerabilities in RUCKUS Unleashed and ZoneDirector | 1.3 | January 27, 2025 | July 21, 2025 |
TSB-2025-002 | TSB 2025-002 - 11ac/Wave-2 R1 Cloud APs random disconnections reported in version 6.2.4.103.260 and earlier release | 1.0 | 2025-04-14 | 2025-04-14 |
