Ruckus R310
Product Detail
The ZoneFlex R310 is the industry’s lowest cost enterprise class 802.11ac access point. The R310 has dual radios (2.4GHz & 5GHz) which are capable of concurrent operation. It is a 2x2:2 stream access point, offering up to 867Mbps of physical layer throughput in the 802.11 a/n/ac 5GHz range, with an additional 300Mbps physical layer throughput in the 802.11 b/g/n 2.4 GHz range. It has a single Gigabit Ethernet port and can be powered by 802.3af PoE or a 12V DC power supply. The R310 has a compact form factor (13.8cm x 13.5cm x 3.3cm) is extremely helpful in easy installation, and enables the power of 802.11ac literally in the palm of your hand.
It is perfect for low client density deployments such as coffee shops, convenience stores and other brick & mortar establishments, where cutting edge WiFi is necessary, but there is only a lean IT staff to manage the network. The R310 is a perfect entry level enterprise class 802.11ac access point that delivers maximum value at minimal cost.
- Model Name:
- R310
- Product Family:
- EOL RUCKUS Products
- Recommended Software:
- Stability Release:
- Technology Release:
Please Wait...
Please Wait...
| ID | Title | Version | Release Date | Edit Date |
| 20200302 | Ruckus AP Image Upgrade Vulnerability | 1.0 | March 02, 2020 | March 02, 2020 |
| 20210129 | AP / ZD CLI Passphrase Vulnerability | 1.0 | January 29, 2021 | January 29, 2021 |
| 20210511 | RUCKUS AP Aggregation And Fragmentation Attacks Vulnerability (aka “FragAttacks”) | 1.1 | May 11, 2021 | October 15, 2021 |
| 20230208 | CVE-2023-25717: RUCKUS AP Web Vulnerability (RCE/CSRF) | 1.2 | February 08, 2023 | May 18, 2023 |
| 20230404 | CVE-2022-47522: Framing Frames: Bypassing Wi-Fi Encryption by Manipulating Transmit Queues | 1.0 | April 04, 2023 | April 05, 2023 |
| 20231128 | CVE-2023-49225: RUCKUS AP Stored Cross-Site Scripting Vulnerability | 1.0 | November 29, 2023 | November 29, 2023 |
| 20240925 | RUCKUS AP Remote Code Execution Vulnerability | 1.2 | October 04, 2024 | October 11, 2024 |
| 20250122 | Security Advisory 20250122: Multiple vulnerabilities in RUCKUS Unleashed and ZoneDirector | 1.3 | January 27, 2025 | July 21, 2025 |
| 20260313 | AirSnitch Vulnerabilities in RUCKUS APs | 1 | March 13, 2026 | March 13, 2026 |
| TSB-2024-003 | TSB-2024-003_Wave_2_APs_stuck_in_Constant_Reboot | 1.0 | 2024-05-29 | 2024-05-29 |
