Ruckus H510
Product Detail
The ZoneFlex™ H510 is a Wave 2 802.11ac (MU-MIMO-capable) Wi-Fi access point with integrated switch in a wall-plate form factor.
H510 features Ruckus' patented BeamFlex + adaptive antenna technology to deliver high-speed 802.11ac WiFi in a low-profile design that can be discretely installed over a standard electrical junction box. H510 allows a range of wired & wireless services to be delivered in hotel guest rooms, student residences, and multi-dwelling units with just a single cable pull per room and eliminates the need for additional switches and power supplies.
Equipped with four Ethernet ports for in-room access, the ZoneFlex H510 can be used to connect a range of wired network devices such as IPtv set top boxes, IP telephones, or networked minibars while simultaneously providing dual band 802.11ac wireelss LAN coverage. An IEEE 802.3af-compliant Power-over-Ethernet (PoE) port on the H510 allows devices such as IP telephones to be powered directly from the wall switch. The H510 itself may be powered via standard PoE or a DC power adapter. The H510 can be deployed as a standalone device or centrally managed by SmartZone, ZoneDirector, or FlexMaster management platforms.
- Model Name:
- H510
- Product Family:
- EOL RUCKUS Products
- Recommended Software:
- Stability Release:
- Technology Release:
Please Wait...
Please Wait...
ID | Title | Version | Release Date | Edit Date |
20210511 | RUCKUS AP Aggregation And Fragmentation Attacks Vulnerability (aka “FragAttacks”) | 1.1 | May 11, 2021 | October 15, 2021 |
20230208 | CVE-2023-25717: RUCKUS AP Web Vulnerability (RCE/CSRF) | 1.2 | February 08, 2023 | May 18, 2023 |
20230731 | RUCKUS Unleashed Authenticated Remote Command Execution Vulnerability | 1.1 | July 31, 2023 | August 01, 2023 |
20231128 | CVE-2023-49225: RUCKUS AP Stored Cross-Site Scripting Vulnerability | 1.0 | November 29, 2023 | November 29, 2023 |
20240925 | RUCKUS AP Remote Code Execution Vulnerability | 1.2 | October 04, 2024 | October 11, 2024 |
20250122 | Security Advisory 20250122: Multiple vulnerabilities in RUCKUS Unleashed and ZoneDirector | 1.3 | January 27, 2025 | July 21, 2025 |
TSB-2025-002 | TSB 2025-002 - 11ac/Wave-2 R1 Cloud APs random disconnections reported in version 6.2.4.103.260 and earlier release | 1.0 | 2025-04-14 | 2025-04-14 |
