Ruckus ICX 7250 Campus Switches
Product Detail
The Ruckus ICX 7250 Campus Switch delivers the performance, flexibility, and scalability required for enterprise Gigabit Ethernet (GbE) access deployment. It raises the bar with up to 8×10 GbE ports for uplinks or stacking and market-leading stacking density with up to 12 switches (576×1 GbE) per stack. In addition, the Ruckus ICX 7250 combines enterprise-class features, manageability, performance, and reliability with the flexibility, costeffectiveness, and “pay as you grow” scalability of a stackable solution.
- Model Name:
- ICX-7250
- Product Family:
- EOL RUCKUS Products
- Recommended Software:
- Stability Release:
- Notes:
Ruckus ICX software currently has two release types; Stability and Technology.
We recommend all customers utilize the Stability Release if it contains all needed features for your network. A Technology Release should only be used if your network requires new features not available in the Stability Release.
Please Wait...
Please Wait...
ID | Title | Version | Release Date | Edit Date |
20190815 | TCP SACK Panic - Kernel Vulnerability (CVE-2019-11477, CVE-2019-11478, CVE-2019-11479) | 1.2 | August 15, 2019 | January 08, 2020 |
20180319 | Security vulnerabilities addressed by NTP (CVE-2016-1549, CVE-2018-7182, CVE-2018-7170, CVE-2018-7184, CVE-2018-7185, CVE-2018-7183) | 1.0 | March 19, 2018 | March 19, 2018 |
20180226 | XSS vulnerability in Ruckus ICX FastIron - (CVE-2013-6786) | 1 | February 26, 2018 | February 26, 2018 |
20230808 | CVE-2023-39904, CVE-2023-39905, CVE-2023-39906: ICX XSS and CSRF Vulnerability | 1.2 | August 08, 2023 | August 14, 2023 |
20250218 | CVE-2024-50607, CVE-2024-50604: ICX Directory Traversal and Image Integrity Check Vulnerability | 1.0 | February 18, 2025 | February 28, 2025 |
TSB-2022-001 | FastIron 09.0.00 and 09.0.10 ‐ Risk of Filesystem Corruption | 1.0 | 2022-02-16 | |
TSB-2022-004 | SSH Service Disconnection | 1.0 | 2022-08-11 | |
TSB-2022-002 | ICX Zero Touch Provisioning (ZTP) Feature – Possible extended delay (DEFECT # FI-252471/FI-255309) | 1.0 | 2022-06-01 | |
TSB-2023-004 | AAA login default action | 1.0 | 2023-07-10 | |
TSB-2022-005 | New PoE chipset does not support releases older than 8.0.95h_9.0.10d | 1.0 | 2022-09-08 | 2023-11-09 |
TSB-2021-002 | After upgrading to 8.0.95c, stack port does blocks traffic | 2021-04-02 |
