RUCKUS Virtual Edge
Product Detail
At its core, the RUCKUS Edge Services Delivery Platform brings the power of the RUCKUS One cloud platform to the edge of the network. By doing so, it transforms how services are deployed and managed, enabling organizations to deliver high-performance, low-latency experiences right where they're needed most—whether that’s in a university campus, a hotel room, or an apartment complex.
RUCKUS Edge virtual appliances are targeted at organizations with specialized IT teams that have expertise in deploying a virtualized infrastructure across central and on-site locations.
- Model Name:
- v-Edge
- Product Family:
- RUCKUS Edge and virtual Edge
- Recommended Software:
Software Name | Release Version | File Type | Last Updated |
RUCKUS Edge Software (GA) (.bin) | 2.3.0.1181 | BIN |
2025-04-02 |
RUCKUS Edge Software (GA) (KVM) | 2.3.0.1181 | QCOW2 |
2025-04-02 |
RUCKUS Edge Software (GA) (.ova) | 2.3.0.1181 | OVA |
2025-04-02 |
RUCKUS Virtual Edge Software (GA) (.bin) | 2.2.0.1066 | BIN |
2024-12-19 |
RUCKUS Virtual Edge Software (GA) (.ova) | 2.2.0.1066 | OVA |
2024-12-19 |
RUCKUS Virtual Edge Software (GA) (KVM) | 2.2.0.1066 | QCOW2 |
2024-12-19 |
RUCKUS Virtual Edge Software (GA) (.ova) | 2.1.0.971 | OVA |
2024-10-21 |
RUCKUS Virtual Edge Software (GA) (KVM) | 2.1.0.971 | QCOW2 |
2024-10-21 |
RUCKUS Virtual Edge Software (GA) (.bin) | 2.1.0.971 | BIN |
2024-10-21 |
What are Spanning tree Edge Ports and how to use them?
Firmware Upgrade - Virtual SmartZone (vSZ)
Firmware upgrade Procedure for Virtual SmartZone (vSZ)
vSZ: Virtual SmartZone Supported Hypervisors
vSZ on 7.0 supports installation on ESXi, Windows Server Hyper-V, KVM CentOS, OpenStack Ubantu and Nutanix hypervisors. For public cloud, it supports installation on AWS, Google Cloud... (continued)
What is Virtual cable testing (VCT)?
What does the S value under AGE column mean in the output of "show dot1x mac-sessions"?
CP - Setting up MAC Registration with a Ruckus Virtual SmartZone vSZ controller
How to set up Cloudpath MAC Registration with a Ruckus vSZ controller
Ruckus Wan Gateway is not syncing configuration with Virtual SmartZone configuration
This Article explains why RWG is not syncing configuration with vSZ
How to Assign an IP address to a virtual interface on a Layer 3 ICX RUCKUS switch
How to Troubleshoot RUCKUS SmartZone Dataplane / Virtual Dataplane client connectivity issue?
This document provides a comprehensive guide for SZ-Dataplane and vSZ-Dataplance client connectivity Issues. It includes necessary steps, troubleshooting tips, and resolution methods.
Working with SNMP Agent on the ZD
This article provides an example setup for querying ZD using a SNMP manager tool.
Steps to Upload Licenses on Virtual Controllers
Licenses are activated and added on the Controller, need to Upload them on the Virtual Controller via GUI
How to gracefully shutdown the Virtual SmartZone Controller
This article explains the step by step process to gracefully shutdown the Virtual SmartZone (vSZ) which is often needed for the maintenance windows or to make any resource level changes... (continued)
Does Virtual SmartZone(vSZ) supports migration from one hypervisor to another
Customer wants to migrate their vSZ from one hypervisor like ESXi to Hyper-V. However, migration from one to another Hypervisor environment is not supported by the vSZ. This is as per... (continued)
Steps to Add Licenses to Virtual Controllers from Support Portal (LiMAN)
Activated AP Licenses and would like to add them on the virtual controllers from LiMAN portal
Can we gracefully shutdown the Virtual IOT (VRIOT) using Command Line Interface (CLI)
Graceful shutdown of VRIOT is not available using CLI. Currently, to perform shutdown the user has to do it from VM machine.
Can VLAN 1 be tagged on Ruckus devices?
This article describes the process of tagging VLAN 1 on Ruckus devices
VLAN configuration on Ruckus ICX switches for Ruckus Wireless WLAN's
Adding untagged & tagged vlan on the same switch port on Ruckus ICX switch.
How to create a VLAN
vSZ - Expanding the VM Hard Disk Size in VMware in SZ 3.5+
Steps to re-size the HDD in the event that more disk-space is required
Ruckus Diagnostic Dashboard - Supported VM Platforms
A summary of the currently supported platforms
VLAN port assignment through Switch configuration profile in RUCKUS One
This article summarizes on how switch configuration profile works in RUCKUS One.
Client running VM (such as a VMWare Virtual Machine), Unable to get a DHCP IP address.
Problem where a Computer running VM (Virtual Machine) is unable to get a DHCP IP address.
WLAN VLAN override from Venue
Override the VLAN configured for a WLAN
VLAN Pooling Configuration
VLAN pooling is a multiple VLAN client IP addressing method.
VLAN configuration of 7731 ports
Information about Ethernet ports of ZF-7731
Widgets not showing info on ZD dashboard
Is it possible to route the Virtual Router Redundancy Protocol (VRRP or VRRP-E) Virtual IP-Address?
Support for Map View on Virtual SmartCell Gateway ?
Support for Map View on SmartCell Gateway
Guide to create a Virtual Machine for the MS Azure Marketplace
Microsoft Azure cloud environment instructions to help create a VM for vSZ installations.
Configure Virtual Switch Redundancy Protocol (VSRP)
Find out what is VSRP and how can it be configured on a device
Virtual Machines are getting IP address but can't access the network
Virtual machine not able to access the network when the interface is set to bridge mode
virtual SmartZone installation on Microsoft Azure
This article provide details on how to install a vSZ on Microsoft Azure cloud platform.
How does Ruckus work with Barracuda firewall
Ruckus provides syslog to Barracuda, filtering username/IP address, to apply ACL policies
VLAN change on AP Ethernet port
Changing VLAN on the AP Ethernet port
SNMP SET to associate a VLAN with a port
How to use snmpset to add associate a VLAN with a port?
How to configure VLAN pooling in SZ100?
These SmartZone CLI commands can be used to configure VLAN pooling
Best Practices for VLAN 802.1Q Tagging
How to correctly assign VLAN 802.1Q tagging (trunking) explained
Configure management VLAN on AP via CLI
This article explains procedure on setting up a management VLAN at the AP level. This can be on standalone AP or a controller managed AP.
Password to login to secure hotspot with Free radius demo integrated with VMware
Customer downloaded the application free radius demo from http://www.ruckuswireless.com/technology/securehotspot/evaluate want to know the password to login into the application
Configuring VLAN for wireless traffic on port based vlan switch configuration
Configuring VLANs for wireless traffic.
Reason for Dashboard Widgets not displaying any Data
This article helps in displaying client statistics on the Dashboard Widgets
How to expand and shrink widgets in ZD dashboard
How to expand and shrink widgets in ZD dashboard?
How to change source ip for dhcp relay agent on a ICX?
Cloud ICX VLAN port assignment through Switch Configuration profile
Use Switch Configuration Profile for VLAN port assignments for ICX switch in Ruckus Cloud
How to configure the AP management VLAN on the SCG controller
This article explains how to assign SCG-managed AP traffic to a specific VLAN.
Brocade Network Advisor - Technical How-To - VLAN Management
How to view, create, edit and delete VLANs and VCS virtual fabrics
Issues with Dynamic VLAN after upgrade (Bradford)
What could cause DVLAN to break after upgrading to 9.7+?
What are compatiblie versions of ZD/SZ and Bradford NAC?
Apple classroom service on multi VLAN environment
Apple classroom service is not supported on multi VLAN environment yet
VLAN IDs lost when ethernet LANs are joined using WiFi
This article explains why VLAN IDs are stripped from ethernet frames when these frames traverse a wireless link.
Virtual vsz agent.
Is virtual vsz have also somekind agent like system so that cluster is in my datacenter and in customer site i have agent that that collects information and do other tasks?
Fastiron Edge X648-prem
Hello. There is a problem. I have a Fastiron Edge X648-prem switch (ver. 07.4.01T3e5), I want to install a 2x10G board on it, took it from a friend, but after installing the switch it... (continued)
VM tools Virtualsmartzone
Hi ! - Is it possible to install VMware tools on the Virtual Smartzone Gateway ? If yes, is there any documentation or i have to refer to the CentOS documentation ?- Does Ruckus... (continued)
Ruckus Virtual SmartZone on Nutanix AHV
Is Virtual SmartZone supported to run on Nutanix AHV clusters? Can't seem to find any information about it and haven't heard of anyone who's tried it. Since AHV is based on... (continued)
Ruckus Virtual SmartZone Essentials version 3.5.1.0.862
Hello, My company have Ruckus Virtual SmartZone Essentials version: 3.5.1.0.862.I need MIB of this product to add it to my supervision but I can't find this MIB Can you help... (continued)
Ruckus Virtual Smart Zone client_mac and uip encryption
Hello,I configured my Virtual Smart Zone controller with a external captive portal.When the user tries to login, he is redirected to... (continued)
How to Troubleshoot High CPU utliization on the Ruckus vSZ-D virtual machine
We are currently running our environment in two virtual machines: Ruckus vSZ-E and vSZ-D According to the webUI we're running the following:Controller Version 3.5.1.0.296Control Plane... (continued)
Troubleshoot Ruckus AP not connecting to Virtual SmartZone cloud controller
I have one VSZ-H + AP R310, but I can not add this AP in to VSZ, everybody maybe help me?
Ruckus Unleashed VLAN Setup
I am not too savvy on the actual administration of networking devices, so I'm hoping for some advice on how to configure my network securely.
I have a gateway router which connects to... (continued)
Virtual SmartZone Firmware Zones
vSZ-H running firmware 3.6.2.0.222 and have near 2000 APs.About 700 APs are R300, ZF7782,ZF7982... Is it possible that we have one vSZ on the old 3.6.2 version (with older APs models)... (continued)
LDAP Auth for SSID Virtual Smart Zone
Is it possible to setup LDAP Authentication on a Wireless SSID? If so How?We have an LDAP AAA Server setup which is used by our Web Authentication Portal but when setting up another... (continued)
Creating HA for Virtual SmartZone-H
Hi,I am back :-) I have just deployed two vSZ version 5.1.1.* on two Proxmox servers. And now wanted to make an High Availability between them. However, I could not find any... (continued)
Virtual vSZ-H & SCI log duration
Hello, we are in talks with a possible client that among other features he requires (we comply with everything) he also wants to have an extensive log of various wifi related... (continued)
Ruckus-Switch VLAN configuration
I have configured a stand-alone static switch (Cisco 3550) with three DHCP pools associated to different VLANS. Clients connected to vlan 1 would get IP addresses in range of... (continued)
Ruckus 7731 and VLAN operation
Hello to all, I have a question I would like to ask... The 7731 wireless bridge is, according to the specs, able to handle multiple VLAN instances. Lets say that I want to create a... (continued)
Ruckus setup with VLANs ZD1200
I just got a new Ruckus ZD1200 and some r610 APs. I am trying to set it up like thisport 1 has ip 192.168.10.254 that is for management onlyport 2 is trunk for guest vlan and corp... (continued)
VOIP Ruckus network
Can you help me improve VOIP in my network, I have around 20 ruckus switches that are connected to one core switch. Now, users are complaining that they have a problem with the voice... (continued)
Why Ruckus?
We are a public school district looking to do a complete overhaul of our wireless network. A bit over 725,000 square feet of indoor space, 4,300 students with nearly 1,400 students in... (continued)
???2?r600?????ruckus
ð?????ruckus,?????,??:1.200??????????“????” ??????? 70??2.ruckus ???????ap ??????????? ???????2.4G?5.8G??????????ruckus ?????????3.????2?r600,????????,2?ap ... (continued)
Does Ruckus Virtual SmartZone 3.5.1 have an API, that can be used by Desktop Lock tool for authentication
We are developing a desktop lock to authenticate users on the Ruckus Virtual SmartZone. Does Ruckus Virtual SmartZone have an API, that can be used by 3rd party tools for authentication
I have a ruckus WiFi network that has recently been moved into Ruckus Cloud Virtual SmartZone 3.6.2.0.222 how long will ZF7982s be supported
I have a ruckus WiFi network that has recently been moved into Ruckus Cloud Virtual SmartZone 3.6.2.0.222 how long will ZF7982s be supported? as out of our 34 APs 29 of them are... (continued)
Monitoring SNMP traps on Virtual SmartZone
There's a couple SNMP traps we want to monitor, but these MiB's are not included in the MiB's download from the Support page. Does anyone have a way to monitor these event traps on the... (continued)
Virtual SmartZone High Scale: 3.4.2.0.152 - Where is map view?.
Google Maps view is clearly visible but I would like to upload my only floor plans and add the APs to the correct location. I am new to Ruckus and assumed that this is an option.
Virtual Smart Zone -High Several AP firmware
Hi,In the platform Ruckus VSZ-H there is the possibility to load several firmware to support old AP(Example: ZF7343). In the literature says that each zone can have a firmware. Any... (continued)
Virtual SmartZone R610 client disconnected
My VSZ version is 3.6.All my R610 Aps under VSZ , the pad client disconnected and join repeatedly.
My WiFi phone connected to the wlan and after serveral minutes, they disconnected and... (continued)
Batch Provisioning for APs with Virtual SmartZone
Is there any more detailed documentation available for batch provisioning of AP's with the Virtual SmartZone? The (very brief) mention of the feature in the administration manual... (continued)
Many Static Public Ip's on Virtual Interfaces
Hi guys,I would really appreciate if you could help me on this, I have a D-Link DIR-686L router with DD-WRT installed on it.I aslo have a block of 29 public static ip from my isp.What I... (continued)
Anyone here is using Virtual Smart Zone Dataplane ?
We are using vSZ-D and tunneling all traffic from AP to Dataplane and we are facing some basic issue like after a while the tunnels crash and need a reboot of the Dataplane to come back... (continued)
Can't register new APs to virtual SZ essentials
Hello everybody. This is my first post as i'm new to Ruckus world. We are having problems adding new APs to Controller. Every 60 sec we have a heartbeat lost from the controller to AP... (continued)
Virtual SmartZone html login form example
Does someone has a captive portal login form with POST action and required hidden fields example to use with VirtualSmartZone?Thanks!
Virtual Smartzone - AAA server authentication
Hello,We would like to authenticate our users using a RADIUS-server, included in the NPS-server from Microsoft Server 2012 R2. They have to login using the 'Web Authentication'... (continued)
Zoneflex 2942 age, usefulness, and options for reuse
We have an older ruckus 2942 at a customers site. It is connected directly to a Charter wireless modem. The Charter modem wireless appears to be turned off.
The location is center of... (continued)
How to create guest wifi with Ruckus AP?
Hi all, one of our client has a Ruckus 7372 wireless AP and wishes to create a guest wireless network separate from their LAN. I'm going crazy here trying to figure out how to create an... (continued)
Ruckus AP command not recognized
Hi Guys,I am trying to connect a brand new Ruckus R500 v 100.0.0.0.127 to a virtual smartzone. however, the AP cannot join the vSZ, nothing in the vSZ's Event tab.when I try the command... (continued)
Add LLDP support to Ruckus devices
This has been an enhancement request open since Jan 27, 2009 3:14pm on the old website.
Not having LLDP support is a major downside for devices positioned as players in the enterprise... (continued)
Ruckus 7372 standalone with multiple SSID and VLANs
Can a standalone Ruckus 7372 have two or more ssid's on different vlans? I would like Eth1 to be a trunk and have the two vlans bridged to my LAN where they will share a dhcp... (continued)
Configuring VLAN's on R710's on Ruckus Cloud
Hi AllI am brand new to the Ruckus product. My client purchased 2 x R710's that he would like to install at his site and manage via Ruckus Cloud. The client is running a Corporate and a... (continued)
Ruckus Unleashed and MS NPS - VLAN assignment
Hi, we have rukus r600 unleashed and have a requirement to authenticate users against active directory and then assign them a VLAN id. We want to do this so that we can have policy... (continued)
Is management VLAN supported on Ruckus Unleashead?
Hi guys, I'm trying to set a management VLAN for the Ruckus Unleashead AP but I can't find that option anywhere.My guess is that it's not supported yet. Can anyone confirm this?Thanks!
What device to split the VLAN traffic from Ruckus?
I have a ZD1100 that I need to convert to using VLANs. That's easy enough to tag each ssid to the correct VLAN. All the traffic comes out of the ZD1100 on one connection so I need a way... (continued)
Ruckus ZoneDirector 3000 setting VLANs problems
Hi All,
Recently I’ve setup different VLANs on my network and would
like to split internal and guest WLANs to two different VLANs.
Ruckus ZoneDirector 3000 with ZoneFlex 7363... (continued)
Testing DPSK vmware image - but what is the password (Ruckus Administrator)
- Testing the DPSK/Secure hotstpot.
- But when downloading the vmware "FreeRadius" it stops at the login (Ruckus Administrator).
But what is the password?
Thanks for... (continued)
Ruckus Road Map
We are working with Systel Company on Egypt on Nile Corniche Project .and we would like to know Ruckus road map for wireless solution
Ruckus H320 DHCP/NAT
Hi,I am doing some testing with a H320, vSZ-H version 3.6.0.0.510, AP firmware 3.6.0.0.771, specifically the DHCP/NAT on the AP feature.I have it working fine over the WiFi, I... (continued)
Ruckus R720 Errors
Running a Ruckus R720 (106.0.0.99.1363) as a standalone unit and everything seems to be running fine from a WiFi perspective. That being said every 5 seconds or so I am seeing the... (continued)
Forti To Ruckus
Hello,i have Fortigate 100D with 4 forti AP that i think to upgrade to R510 unleashed.Today i have 2 SSID in seperate subnets that managed by Fortigate in gate mode and restrict with... (continued)
How to integrate Virtual SmartZone Controller with Aradial Enforcer
Model: Virtual SmartZone - High Scale, AP firmware : 3.2.1.0.642
I need to configure this Ruckus Controller with Aradial Billing Software. So that our hotspot users can authenticate... (continued)
Virtual SmartZone API : How should serviceTicket be used?
I'm currently building a service to communicate with a Virtual SmartZone. On startup, the service calls the v7_0/serviceTicket route and receives a service ticket back, which is used as... (continued)
Current Migration Process from ZD 3000 to virtual Smartzone Essentials
I have decided to move to a virtual SmartZone controller because Ruckus informed me that the new SmartZones would allow autonomous WLANs to continue running on meshed APs if the... (continued)
Virtual Interfaces getting port utilization over threshold
Hi Guys, in our network we have 1 ZD1200, 4 R700 and 2 R710 all on 9.12.2.0 build 204 firmware ... and we enable snmp to monitor port utilization and i can see that... (continued)
HtH: Upgrading a Virtual SmartZone Cluster - New video, KB articles, and tech doc
Greetings, Adding to our SmartZone material on the How-to-Hub, please find details on our newestoffering:
Subject: Upgrading a Virtual SmartZone Cluster– new video,... (continued)
