Product not found.
RUCKUS Indoor APs
RUCKUS R370
The RUCKUS® R370 offers dependable, high-performance Wi-Fi 7 (802.11be) networking at a budget-friendly price. Equipped with patented RUCKUS technologies for optimizing performance and reducing interference—just like our top-tier access points—it ensures exceptional user experiences. Designed in a compact form factor, it's tailored for smaller venues while keeping costs affordable.
The R370 is an ideal choice for lower-density environments with less coverage areas including small and medium-size economy hotels and motels, small and medium-size businesses, retail locations, restaurants, and multi-tenant small offices and branch offices.
The RUCKUS R370 is a dual-band concurrent indoor Wi-Fi 7 AP that delivers 4 spatial streams (2x2:2 in 2.4GHz, 2x2:2 in 5GHz) and supports Wi-Fi 7 features, offering class leading performance with a combined data rate of 3.57 Gbps. Furthermore, a 2.5 Gbps Ethernet port minimizes wired backhaul bottleneck for full use of available Wi-Fi capacity.
RUCKUS H670
The RUCKUS H670 is an AI-driven, Wi-Fi 7 wall-mounted access point that delivers ultra-fast, reliable, and secure in-room connectivity for hospitality, multi-dwelling units, education and enterprise environments. With multi-gigabit wired backhaul, integrated IoT radios, patented RUCKUS RF technology, and AI-powered network optimization, the H670 transforms each room into a high-performance connectivity hub, designed for the experiences users expect today while ready to deliver tomorrow’s networks capabilities.
RUCKUS R575
RUCKUS R575: Midrange Wi-Fi 7 AP for Indoor Deployments
The RUCKUS R575 is a ceiling-mounted Wi-Fi 7 tri-band concurrent indoor access point that delivers 6 spatial streams (2x2:2 in 2.4GHz, 5GHz, and 6GHz). With MultiLink Operation (MLO), Preamble Puncturing, 4K QAM, it achieves a combined data rate up to 9.3 Gbps, ensuring exceptional wireless performance in demanding environments.
Two 2.5 Gbps Ethernet uplink ports deliver smooth, high-speed wired backhaul and 802.3at versatile power options offers streamlined deployment.
RUCKUS R770
The RUCKUS R770 is a high-end Wi-Fi 7, tri-band concurrent indoor AP that delivers 8 spatial streams (2x2:2 in 2.4Ghz, 4x4:4 in 5Ghz, 2x2:2 in 6Ghz) and supports Wi-Fi 7 features such as Multi-Link-Operation (MLO), Preamble Puncturing, 4K QAM Modulation, and 320 Mhz Channels. It delivers industry-leading performance environments with a combine data rate of 12.22 Gbps. Furthermore, a 10Gbps Ethernet port eliminates wired backhaul bottleneck for full use of available Wi-Fi capacity.
RUCKUS R350e
The RUCKUS® R350e offers dependable Wi-Fi 6 (802.11ax) connectivity at an affordable price point. It delivers a superior user experience by leveraging patented RUCKUS technologies for enhanced performance and interference management. With its 4-stream AP configuration (2x2:2 in 2.4GHz, 2x2:2 in 5GHz), it achieves speeds of up to 1200Mbps in the 5GHz band and 574Mbps in the 2.4GHz band.
RUCKUS R670
The RUCKUS R670 is a mid-range Wi-Fi 7, tri-band concurrent indoor AP that delivers 6 spatial streams (2x2:2 in 2.4GHz, 5GHz and 6GHz or 2x2:2 in 2.4GHz and 4x4:4 in 5GHz in dual band mode) With Multi-Link-Operation (MLO), Preamble Puncturing, 4K QAM Modulation and 320MHz channels. It delivers industry-leading performance environments with a combined data rate of 9.34 Gbps. Furthermore, a 5 Gbps Ethernet port eliminates wired backhaul bottleneck for full use of available Wi-Fi capacity.
RUCKUS R560
The RUCKUS R560 is our mid-range tri-band concurrent Wi-Fi 6E indoor AP that supports 6 spatial streams (2x2:2 concurrent in 2.4GHz, 5GHz, and 6GHz).
The RUCKUS R560, with OFDMA and MU-MIMO capabilities, efficiently manages up to 1536 client connections and is designed to address the needs of high throughput indoor locations such as hotel/MDU hallways, student housing, and classrooms. It includes a 5Gbps multi-gigabit Ethernet port to mitigate backhaul capacity bottlenecks.
Additionally, the R560 has an onboard IoT selectable radio and supports wireless standards beyond Wi-Fi in combination with the Ruckus IoT Suite.
RUCKUS R760
The RUCKUS R760 is our highest capacity tri-band, tri-concurrent Wi-Fi 6E access point (AP) that supports 12 spatial streams (4x4:4 in 6GHz, 4x4:4 in 5GHz, 4x4:4 in 2.4GHz).
The R760, with OFDMA, TWT and MU-MIMO capabilities, efficiently manages up to 1536 client connections with increased capacity, improved coverage and performance in ultra-high dense environments. Furthermore, a 10 Gbps multi-gigabit Ethernet port mitigates backhaul capacity bottlenecks.
Additionally, the R760 is IoT ready and supports wireless standards beyond Wi-Fi in combination with the RUCKUS IoT Suite
RUCKUS H350
The RUCKUS H350 is a Wi-Fi 6 (802.11ax)  Wi-Fi access point with integrated switch in a wall-plate form factor.
H350 features Ruckus' patented BeamFlex + adaptive antenna technology to deliver high-speed 802.11ax WiFi in a low-profile design that can be discretely installed over a standard electrical junction box.  H350 allows a range of wired & wireless services to be delivered in hotel guest rooms, student residences, and multi-dwelling units with just a single cable pull per room and eliminates the need for additional switches and power supplies.
Equipped with two Ethernet ports for in-room access, the RUCKUS H350 can be used to connect wired network devices such as IPtv set top boxes while simultaneously providing dual band Wi-Fi 6 WLAN coverage and BLE or Zigbee coverage with an IoT Radio.  The H350 may be powered via standard PoE or a DC power adapter.  The H350 can be managed by SmartZone, ZoneDirector, Cloud or Unleashed management platforms.
RUCKUS H550
The RUCKUS H550 is a Wi-Fi 6 (802.11ax)  Wi-Fi access point with integrated switch in a wall-plate form factor.
H550 features Ruckus' patented BeamFlex + adaptive antenna technology to deliver high-speed 802.11ax WiFi in a low-profile design that can be discretely installed over a standard electrical junction box.  H550 allows a range of wired & wireless services to be delivered in hotel guest rooms, student residences, and multi-dwelling units with just a single cable pull per room and eliminates the need for additional switches and power supplies.
Equipped with four Ethernet ports for in-room access, the RUCKUS H550 can be used to connect a range of wired network devices such as IPtv set top boxes, IP telephones, or networked minibars while simultaneously providing dual band Wi-Fi 6 WLAN coverage and concurrent BLE & Zigbee coverage with dual IoT Radios.  An IEEE 802.3af-compliant Power-over-Ethernet (PoE) out port on the 901-H550-XX00 SKU, or a 48V passive PoE out port on the 901-H550-XX02 SKU, allows devices such as IP telephones to be powered directly from H550.  The H550 itself may be powered via standard PoE or a DC power adapter.  The H550 can be managed by SmartZone, ZoneDirector, Cloud or Unleashed management platforms.
RUCKUS R350
The RUCKUS R350 represents an evolution in Access Point (AP) technology - it's not just a Wi-Fi AP, it's a Wireless Technology Hub.  It's a 4 stream AP (2x2:2 in 2.4Ghz, 2x2:2 in 5GHz) that comes with Wi-Fi 6 (802.11ax) capable of delivering 1200Mbps in 5GHz and 574Mbps in 2.4GHz. Additionally, the USB port allows expansion for any future IoT protocol, all without breaking the bank.
RUCKUS R550
The Ruckus R550 represents an evolution in Access Point (AP) technology - it's not just a Wi-Fi AP, it's a Wireless Technology Hub.  It's a 4 stream AP (2x2:2 in 2.4Ghz, 2x2:2 in 5GHz) that comes with Wi-Fi 6 (802.11ax) capable of delivering 1200Mbps in 5GHz and 574Mbps in 2.4GHz.  The Ruckus R550 also comes with built-in BLE & Zigbee, and the option to expand to other IoT wireless protocols in the future.
RUCKUS R650
The Ruckus R650 represents an evolution in Access Point (AP) technology - it's not just a Wi-Fi AP, it's a Wireless technology hub. It's a 6 stream AP (4x4:4 in 5GHz, 2x2:2 in 2.4GHz) that comes with Wi-Fi 6 (802.11ax) capable of delivering 2400Mbps in 5GHz and 574Mbps in 2.4GHz.
Wi-Fi 6 Multi-gigabit wireless technology is custom designed for ultra-high density deployments using technologies like OFDMA and has the added benefit of increasing your phone's battery life, thanks to the Target Wake Time (TWT) feature.
Additionally, the R650 comes with built-in BLE and Zigbee, and the option to expand to other wireless protocols in the future. With the R650, adopting a new wireless technology is as if it's a wireless language, the R650 will be able to speak it.
RUCKUS R750
The Ruckus R750 represents an evolution in Access Point (AP) technology - it's not just a Wi-Fi AP, it's a Wireless technology hub. It's an 8 stream AP (4x4:4 in 5GHz, 4x4:4 in 2.4GHz) that comes with Wi-Fi 6 (802.11ax) capable of delivering 2.4Gbps in 5GHz and 1.148Gbps in 2.4GHz.
Wi-Fi 6 Multi-gigabit wireless technology is custom designed for ultra-high density deployments using technologies like OFDMA and has the added benefit of increasing your phone's battery life, thanks to the Target Wait Time (TWT) feature.
Additionally, the R750 comes with built-in BLE & Zigbee, and the option to expand to other wireless protocols in the future. With the R750, adopting a new wireless technology is as if it's a wireless language, the R750 will be able to speak it.
RUCKUS R850
The Ruckus R850 is a new dual-band concurrent 12 stream Wi-Fi 6 Access Point, capable of delivering 4.8Gbps with 8x8:8 5GHz radio and 1.148Gbps with a 2.4GHz radio.
The R850 is designed for high density, high performance applications, and has on-board BLE & Zigbee radios for IOT Applications.  The R850 supports a 5Gbps PoE_in Ethernet interface that can operate with uPOE, PoH, and 802.3at power, and has an additional 1Gbps Ethernet interface and a USB port.
Working...Please wait
This is here to prevent you from accidentally submitting twice.
The page will automatically refresh.
Alert!!
Close
